CW Display Keying Waveform
Todd
Todd Member
edited June 2017 in SmartSDR for Windows
I hope that this is not the dumb question of the day, but I am just getting back into CW and setting up this mode on my 3000 with PowerSDR - KE9NS. Is there a way to display in the upper panadapter (set on panascope) the CW transmit keying waveform when using CWX or a straight key?  I can see this waveform (vertical spike) when I send CW with a "sound card" program like MixW or MRP40.
Also, if I switch to panascope  and I use CWX, I can see a moving type scope display in the bottom half of the pan adapter, but how can I adjust the level because the display is peaking vertically?
Thanks and 73, Todd K1OD
