Mon tx audio in smartsdr ios app
WV9L
WV9L Member ✭✭
edited February 2020 in FLEX-6000 Signature Series
Is it possible at all to monitor tx audio on the ios app? I have tried turning MON on and adjusting levels. No such luck. Ive all of a sudden been getting bad audio reports. Would be nice to hear the audio myself. Happens both on WAN via VPN and on local LAN.
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited May 2017
    Unless the radio has gone south, most sudden audio distortion problems are caused by "RF in the shack" If you have a dummy load and a spare HF receiver, you could verify the possible RF problem.
    Jim, K6QE
  • WV9L
    WV9L Member ✭✭
    Still is it possible to use the monitor function with the ios app?
  • Andy M5ZAP
    Andy M5ZAP Member
    Hi,
    This is the method I use
    1 - Save a Global profile that is configured to use the audio setup process that is detailed in previous posts, this uses full duplex and the transverter output (Into a dummy load) whilst receiving the transmitted audio. Set this profile up on a PC using SSDR and check it works OK. 2 - Open that profile in SSDR for iOS
    3 - Whilst transmitting on the iOS device use DAX on a PC to record the receive audio, I use the excellent freeware program "Audacity" to record. You can run DAX on a PC while running SSDR for iOS on another device no problem.
    If you need more of an explanation I could write a step by step guide this weekend, as it would be better if I went through the process again myself while writing the guide.
    Hope this helps, worked a treat for me, just wish that SSDR for iOS had a software version of the downward expander so I could get as good an audio setup on iOS as on my PC.
  • ThisUserDoesNotExist
    ThisUserDoesNotExist Company Adviser ✭✭
    Jeromy,
    I just want to add that the MON feature of the iOS App has been implemented the same way as for the Windows App.
    Marcus, DL8MRE
  • Andy M5ZAP
    Andy M5ZAP Member
    edited May 2017
    Hi Marcus
    Unrelated to your comment but in my procedure above there is a reason you need to setup the FDX listening global profile in SSDR for Windows. And then select it in iOS , there was some functionality I couldn't setup in the iOS app. I will try and repeat tonight. It might even be the FDX select itself but I can't remember!!. I will repeat and post result.
  • WV9L
    WV9L Member ✭✭
    edited February 2019
    I finally fig it out and got all my profiles adjusted. I use a wired headset, a bluetooth, the stock apple headphones, and the handsfree in my chevy colorado. In a pinch ill go direct thru the phone, if i see a country i need on the spotter. Thats an awesome new feature in itself. Thanks for all your hard work Marcus. Got the levels all set. Thanks!!
