SmartSDR for iOS and digital modes
Carl N8VZ
Carl N8VZ Member ✭✭
edited April 2020 in FLEX-6000 Signature Series
I've seen some scattered references to folks running digital modes (JT65, PSK31) on their iPad's using SmartSDR for iOS.  However, I can not find any descriptions of how they set it up.  What apps they used to interconnect with SmartSDR for iOS, etc.  Can someone point me to a description of the how to set this up?  Thanks. -- 73 de Carl N8VZ
  • Ria
    Ria Member ✭✭✭
    edited November 2019
    As far as I know, right now you cannot run digital modes on your iPad directly (except CW via CWX).
    You can run SSDR for iOS and via DAX do digital modes on a Windows PC.
    You can also run smartSDR on the desktop, run the digital mode program there and use RDP, VNC or something else to view the PC desktop.
  • Carl N8VZ
    Carl N8VZ Member ✭✭
    Thanks, Rita! I was kind of afraid that might be the answer. Do you know if it's being worked on for a future release of SmartSDR for iOS?
  • Carl N8VZ
    Carl N8VZ Member ✭✭
    edited June 2018
    Sorry, Ria, autocorrect misspelled your name.
  • Ria
    Ria Member ✭✭✭
    edited May 2017
    Your best bet is to ask Marcus, DL8MRE. He developed the app. From my experience sharing audio data among apps in iOS is going to be a challenge so I don't really see the same arrangement on Windows applying to iOS where you have a DAX program and then your programs use audio devices.
    However, since DAX is available via the API, it's possible for someone to write a standalone digital mode app on iOS that connects directly to the rig via ethernet and gets the audio data that way.
    Something to think about.
  • Bob- W5TX
    Bob- W5TX Member ✭✭
    Paradise is never having to apologize for autocorrect!
  • Carl N8VZ
    Carl N8VZ Member ✭✭
    edited May 2017
    Thanks, I'll ask Marcus.
  • Ria
    Ria Member ✭✭✭
    edited May 2017
    autocorrect is funny
    www.damnyouautocorrect.com
    (PG-13, fair warning)
  • Gastonet
    Gastonet Member ✭✭
    edited April 2020
    Does anyone know this app? https://audiob.us/ It can interconnect apps between them in iOS kind of Virtual Audio Cable, FlexRadio Dax, etc.
