Flex 6300 using SmartSDR 1.10.8 has a problem with missing dits when sending CW.
W3PV
I am a CW only operator and since I purchased my Flex 6300 I have been noticing a disturbing feature of my Flex dropping dits from words sent by CW probably caused by SmartSDR v.1.10.8. It seems to be worse when sending my callsign letters 3 and P. Is there a fix for this problem?
I experience the same basic problem when using CWX preloaded CW messages! However it simply stops sending for a second & then continues! I've reloaded the CWX setup messages with no resolution.?This is an intermittent-- annoying! And started with the 1.10.8 update!!0
External keyer, I have yet to get Flex cw keyer to work. 73 Lew n4co0
So far, I haven't noticed that. I am primarily CW and work around 25 WPM. I will keep an eye (ear) out.0
As a 100% CW operator this 6300 is of no use to me if the manufacturer can't get it to work properly. I can send CW through CWK but my direct keying does not work.
Roon - W3PV
I haven't seen the problem when using CWX, only when using the key. Is there another updaate coming soon.... I hope?
Which version are you using?
@Ron - you may want to check the release notes for the later versions of SmartSDR. Version 1.10.8 is two public releases behind. Of course it may all change again soon (Hamvention next version release??)
GL & 73
Steve K9ZW
I am using 1.10.16.910
I cleaned both contacts on my Vibroplex. Problem has disappeared.
Stan W8NNX
- 322 Shack Infrastructure
- 227 Networking
