N1MM and Dx Log mutes audio in SO2R with Maestro - why?
Kari Gustafsson SM0HRP
Kari Gustafsson SM0HRP Member ✭✭
edited January 2019 in FLEX-6000 Signature Series
I have tried to get both Dx Log and N1MM to produce audio in other slice (e g 20 m ANT 1) when transmitting on other slice on another band (40 m ANT 2) but no luck. Audio gets muted by Maestro with 6700. I have stereo reception with both N1MM and DX Log. Neither program has a feature to make a selection to avoid this ( e g "Untick mute other slice.."). Working CW and SO2R and different antennas on ANT1 and ANT2.
Anyone getting N1MM to work SO2R CW with audio in one ear while doing CQ on another band?
  • Kari Gustafsson SM0HRP
    edited January 2019
    I solved the issue by following K9CT instruction for setting up N1MM and 6700 and using FDX and a making a "Global SO2R" profile. So the cause was propably missing to use "FDX" setting.
