FLdigi and Flex 6500 working split
Paul F6EXV
Hi all
I just cannot figure out how to work split in digital modes with FLdigi (versiuon 3.23.21) and SmartSDR (version 1.8.4)
I have read some documentation about split, but many DXpeditions have a split wider than just 5 KHz. Can I open a second instance of FLdigi on either a separate VFO on the same slice, or do I need to open a second slice ?
How do I configure DAX and CAT ?
Thanks in advance for any help, or pointing me to the proper tutorial.
Paul F6EXV
Paul F6EXV
Use one slice and adjust the TX frequency using XIT.0
Thanks Tim for fast reply. I had read about his option, but it does not make it possible to track within the pile up, as I do not see the surroundings of the frequency which I will TX on. (I suppose the XIT increments are 10 Hz, which makes it vety hard to "jump". Is it possible to open a second instance of FLdigi, to be set on the second VFO (or slice) ?
It is possible to use multiple instances of Fldigi, but there isn't a way to sync the receiver slice with the transmit slice meaning you will have to manually enter calls if you are using the Fldigi log.0
Tim, I am putting myself in the position of the DX hunter, so the callsign can be entered manually once, it will not change untill I work another DX working split, so this is not an issue. Ideally, I want to be able to track the calling pile-up which may well extend over a full 20 Kc of bandwidth.
In that case, what do I need to change in the second instance of FLdidi (if anything). I did download the sliceB.xml, sliceC.xml and sliceD.xml in addition to slice A (4 slices for the 6500).
When I open a second slice on SmartSDR, the DAX control panel still will not show slice B as being streaming. Is this normal ?
Paul
It's expected if you haven't configured that instance of Fldigi to use a unique settings folder and haven't configured the audio for DAX RX2 and DAX TX. The XML files only configure CAT.0
I use successfully 2 instance of Fldigi and 2 slices no doubts is very operative environment0
Hi Sergey, Can you give us a step by step of how did you do it? Thanks0
- 685 The Flea Market
