DxLab Commander only tracking slice A
WA5YOM
I am new to the 6700 so I may not be using the correct terminology. I have my Flex working with DxLab commander 12.6.1 It only works with Slice A. regardless of whether it is the active slice or not. How wo I make it work with any active slice?, Thanks, Tim WA5YOM
A discussion on how DXLab Suite's Commander interacts with the Flex 6xxx radios is here: http://www.dxlabsuite.com/dxlabwiki/FlexSignature In general, when using 2 slices, Commander considers Slice A to be the receive VFO and Slice B for transmit. I would suggest that, if you aren't already a member, that you join the DXLab Suite Yahoo group and pose your questions & comments there. The software's author, Dave, AA6YQ, is active almost daily and he owns a Flex. You can join through this portal: https://groups.yahoo.com/neo/groups/dxlab/info0
