Can I force SmartSDR CAT to connect to particular radios?
K9SO
K9SO Member ✭✭✭
edited March 2017 in FLEX-6000 Signature Series
I operate 6500's at two different sites and use SmartSDR CAT for various functions. Is there  any way to force SmartSDR CAT to connect to a particular site without completely shutting down one of the stations?
I'd like to keep both stations powered up at the same time (to avoid the long boot times) but when I do that, I don't seem to be able to connect CAT to the one I want.
Fred
K9SO
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited March 2017
    I had the same problem. To mickey mouse around it, I have computers at both remote sites. I use one remote computer to bring up SmarSDR and connect to the other radio directly using OpenVPN. I then, use Teamviewer to operate them simultaneously from my client site. At the remote sites I use the Asus 88U router as it can configured in the TAP mode for OpenVPN.
    Jim, K6QE
  • Cal  N3CAL
    Cal N3CAL Member ✭✭
    edited March 2017
    Fred,
    Here is an article on using the filter.txt file.  I'm not sure if this will suite your needs completely but it's worth a read?    The filter.txt file will allow to force a specific PC to connect to a specific radio and this includes DAX and SmartSDR CAT too.
    https://helpdesk.flexradio.com/hc/en-us/articles/202549169-How-to-prevent-multiple-FLEX-6000s-from-s...
    73 de Cal/N3CAL
