Noise Bursts Only on 20m only and when key down on CW - anyone ever seen this?
Ed
I recently installed SmartSDR v1.10.16.174 and have never seen this before then, on 20m only if I hit the key the panadapter display jumps. I set the width to cover thru 30m and see these burst across the display yet when I switch to 30m band everything is fine.
Thank You
Ed K1EDG
Thank You
Ed K1EDG
AGC Issues ?0
Do you have your Display -> Weighted Average turned on? I had a similar look up and down the band with weighted average turned on.0
Thanks for your reply, Dudley at Flex found that the "weighted averaging" was on on 20m, turned it off and problem is gone...TU...Ed0
Thanks for your reply, Dudley at Flex found that the "weighted averaging" was on on 20m, turned it off and problem is gone, you were correct! Thanks 73..Ed...
- 683 The Flea Market
