SLICE A / SLICE B logging frequency
K3ZJ - Dave
K3ZJ - Dave Member ✭✭
In CQ160 contest I was using slice A to run and slice B to tune for new stations.  When I found something to work on slice B, I changed the transmit to B and worked the station.  BUT the frequency entered into the logging program (N1MM+) was the frequency of abandoned slice A, not the transmit/receive frequency of slice B.  So the frequency enetered is wrong.  Note:  this was NOT split, this was simplex using slice B.  How does one correct this?
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    You may need to explore setting up as SO2V or SO2R.  In SO2R mode, N1MM+ will set up two entry windows, one for each Slice, and log whichever slice is the active slice when you hit the enter button.  I assume SO2V is similar, but I haven't messed around with it.  I use SO2R mode without full duplex as what Chris Tate calls "Enhanced SO2V" mode -- both "radios" on the same band, but not operating full duplex.
