N1MM+ DDUTL issue
Paul M
I am stumped as to why but if I start DDUTL before N1MM+ then N1MM+ will not connect to the radio. If I start N1MM+ first and then DDUTL all is well. There are no port conflicts between the two programs. This seems to be the issue that I was having during the RTTY contest and Wednesday CWT.
I do not remember this issue before the BETA software. I have cross posted on the DDUTL Forum
Paul de W4PGM
Paul de W4PGM
1) Do you have the latest version of DDUtil? I think there was a small API change before the latest one.
2) DDUtil might be grabbing a port that you may not realize is being used?
3) What ports do you have defined in ddutil, and what ports are you using for the rig?0 -
DDUTL 3.2.5.01 No ports defined in DDUTL currently. I am just using it for the HRD Server until I can get mini deluxe back running. In the rig for n1mm+ 12 rig control, 30 PTT, 16 WinKeyer. I'll check on the latest version.0
- 692 The Flea Market
- 119 Aurora
