SmartSDR for Windows has lost connection to the radio. Please reconnect. 1.10.15 Beta
Moose
I typically use my Maestro with my Flex-6500, but when I use SmartSDR 1.10.15 Beta on a Windows 10 machine I frequently get the error: "SmartSDR for Windows has lost connection to the radio. Please reconnect." I've had this happen 4 times in the last 3 hours this morning. This is actually one reason I use the Maestro a lot is that it is more stable it seems.
How can I keep this from happening.
73 Chris AK4SK
73 Chris AK4SK
Try connecting a LAN cable directly between the radio and computer. If it works there you have a network device or LAN cable failure. Make sure the LAN on your computer is not set to go to sleep. Mack W4AX Alpha Team0
If you are directly connected radio to PC with no network issues; Open the Task Manager and check your CPU Utilization. This problem is usually associated with high CPU usage starving the radio for service. Check for other apps consuming cpu cycles.0
Thanks Mack. I did have the LAN setting enabled that allowed the computer to put that to sleep. That is now off but the problem continues to occur. I'm using a switch so that I can connect my Maestro, Flex-6500, and wifi range extender together. When I get home I'll try a direct connection.
73 Chris0 -
Thanks Bill. I still need to try the direct connection method. However, my CPU utilization is 25-35% and memory is 15%. That should be sufficient, correct?
73 Chris0 -
The error message you received indicates that the client (SmartSDR for Windows) has not received any network data from the radio for 15 seconds and resets the network connection. When this happens, if you can immediately restart SmartSDR and connect to the radio, meaning that the radio is still alive, then 99% of the time this is due to network related issues. If you have to do a long power button press on the radio to reboot it, then the issue was the radio stopped responding. You need to figure out which error condition you have before starting troubleshooting.
If it a network issue, then you should investigate what might have caused the network to not provide sufficient throughput to operate the radio. Look at the entire end-to-end connection. Is there a wifi element in the connection? If so, that is the first place to look. Wifi connections are slower and more unreliable that a wired Ethernet connection. For every device connected to your wifi, the bandwidth decreases by 1/2. In addition, wifi is only half duplex. so that exacerbates congestion issues. Adding wifi extenders cause these and additional problems by increasing the amount of latency on the wifi link.
Mack's recommendation is essentially a troubleshooting step where all of the network components in the end-to-end connection are eliminated. This is a classic "divide and conquer" method of isolating the problem area.0 -
Thanks Tim. I never have to restart the radio to reconnect. My Maestro, 6500, PC, and wifi range extender all connect to the same switch. So through the switch the 6500 is directly connected to the PC. Connected this way does it still have issues due to wifi?
73 Chris0 -
What connects through the wifi extender?0
My shack is upstairs and my modem and main wifi router are downstairs. So I use the range extended upstairs as both a range extender and a bridge. It provides a better wifi upstairs than I would get from the main router and it provides wired internet (or wifi if I wanted) to the PC and Maestro via the bridge function. The Maestro, 6500, and PC all connect to the switch. The extender has only one wired connection and that is to the switch.
Did that answer your question?
73 Chris0 -
Just so I fully understand, the wifi extended is used primarily so that the PC and Maestro in the shack can get Internet access?
Is it also a safe assumption that the devices upstairs (radio, Maestro & PC) physically connected to the range extender (the Ethernet bridge ports) also get their IP addresses via the wifi router downstairs?0 -
Yes, all the wifi extender does is provide internet access. I can disconnect it from the switch and lose no functionality from my radio, PC, and Maestro. For a while I didn't even have it and I just connected to the downstairs wifi the best I could. As a means of troubleshooting I will disconnect it.
I think that is correct that all the upstairs devices get their IP address from downstairs but I will double check.
Thanks again,
Chris0 -
OK. I have a good picture of your network configuration now. Thanks.
In general, if I had to take a guess, I'd be suspect of the quality of the switch functionality in your wifi extender. They are designed for handling bridged wifi traffic and it may not be up to the task of handling the data being streamed out of the radio to the PC or Maestro. I'd consider using an external switch, like a Netgear GS308 that is connected to the wifi extender and then everything else in the shack connected to the GS308.0 -
Unless we're saying the same thing or I'm not understanding you, I do have it connected the way you recommend. I'm using a NETGEAR ProSAFE FS105NA 5-Port Fast Ethernet Switch. The 6500, Maestro, PC, and bridge/extender all connect to it. There is only one wired connection to the bridge and that is between the bridge and the switch so I'm not using the bridge as a switch (It only has two ports anyways). None of the radio to PC or Maestro to radio data goes through the bridge. I don't think? It all goes through the Netgear switch. Does that sound right?
Thank you for your time and help.0 -
Ahh, I see now.
it is possible you have a marginal network cable. I always suspect the physical layer when troubleshooting network performance
Where I'd look next is optimizing the network adapter in the PC. This HelpDesk article address network adapter performance tuning.
https://helpdesk.flexradio.com/hc/en-us/articles/202118518-Optimizing-Ethernet-Adapter-Settings-for-...
And I forgot that you also want to use the network quality monitor in SmartSDR to see if you are dropping packets before and after making any adapter changes.0
Thanks again Tim. I think I know a lot more about what I need to check.
73 Chris0 -
I connected the radio directly to the computer last night and the issue stopped. I used the same LAN cable that I do between the radio and the switch. I guess next I'll try a different LAN cable between the switch and the computer.
Thanks for all of the suggestions.0 -
A GS105NA 5-Port version is in use here. On rare occasions (one / week) a hic-up occurs on the network. If connected direct to PC - never a problem (months at a time - 24/7). I'd suggest upgrading the switch. Also a fan of shielded Cat-6 cable, ground loops notwithstanding.
GL & BRs0 -
Thanks I may have to do that.0
