FlexControl using the Flex6xxx and one of the two usb built in ports - Possible?
Keith Flint
Is this possible? I am running out of USB ports on my PC
Hi Keith, No, Since the FlexControl is associated with the client (SSDR, etc) FRS decided not to implement a connection to the radio. Rather it must be connected to the client device. You might consider adding a 4 port USB hub to one of the USB ports on the PC to expand the number of USB connections. Regards, Al / NN4ZZ0
- 688 The Flea Market
- 105 Aurora
