Flex SSDR Cat not working
Pat N6PAT
Pat N6PAT Member ✭✭
edited November 2019 in FLEX-6000 Signature Series
Everything working fine last night and then when I boot up my computer this morning I get the following:
I get the same message when I try to start Cat after I boot up the Flex
Running v1.9.7.169 with a F6.7K in Windows 8.1
Anyone else having this issue?
  • David
    David Member ✭✭
    edited March 2017
    I'm guessing you have tried rebooting. You could try re-installing SSDR if that doesn't work try a clean install by doing a full uninstall of all FlexRadio programs, reboot, and re-install. If that doesn't help then I would suggest open a support ticket with FlexRadio.
  • Ria
    Ria Member ✭✭✭
    Was this after a windows update?
  • KF4HR
    KF4HR Member ✭✭
    Last week I had a situation where my SSDR Cat would only connect for a couple of seconds, then disconnect (indicating NONE as the CAT process).  Reloading SSDR from scratch solved the problem.  As Ria mentioned, this problem seems to occur whenever I get a Windows update, but (so far) I've found that reinstalling SSDR fixes the problem.  Odd situation, but at least I found a work around.
  • Ria
    Ria Member ✭✭✭
    edited January 2017
    I've had it happen once and that was after the Windows 10 anniversary update. I think it corrupts or does something else to the drivers or something.
  • Pat N6PAT
    Pat N6PAT Member ✭✭
    edited September 2018
    Very strange.I uninstalled and reinstalled SSDR then got the following:
    For some reason it didn't reinstall the drivers. So I uninstalled and reinstalled again and this time it worked. There were no recent Windows updates and it was working fine when I shut down last night.
    Oh well, at least it's working now. Thanks for the help
  • Ernest
    Ernest Member ✭✭
    If you need the Flex VSP driver to be install, here where you can find the installation software to do it: C:/program files/flexradio systems/flexVSP/flexVSPInstallller_64
    That's where I found mine in.  Hope this helps
  • Pat N6PAT
    Pat N6PAT Member ✭✭
    edited January 2017
    Thanks.
