SmartSDR v1.10.15 BETA
dlwarnberg
Tim,
FYI....Did a clean uninstall of the previous Beta version after reboot did an install of this new beta... VSP drivers did not install. Investigating
David
David
Just did the 1.10.15 install. Went smooth for 6300 and Maestro. All drivers present and accounted for. Go Flex...
If you were running SmartSDR v1.10.8, then you already have the latest version of the FlexVSP drivers and they will not reinstall.
Update... second install and reboot installed the VSP drivers... not sure what happened there.. all working fine now.
Thanks0 -
I did not uninstall the previous version. I installed this beta, updated my FRS6500 and my Maestro and everything is working as it should. Simple, pain-free upgrade!
Can I just delete the previous versions directories or should I use the Windows Uninstaller?
David G4NRT0 -
SmartSDR Cat and DAX Control Panel show v1.10.15. Drives may be same but shows updated version.
The release notes discusses the un-installation of previous versions.0
You should ALWAYS use the uninstaller that comes with each version of SmartSDR.
As per the Release Notes, if you plan to uninstall previous versions of SmartSDR it is recommended that you do it before installing the latest version. If you decide to uninstall previous versions now and encounter any issues, then you will have to reinstall 1.10.15 BETA.
or you can just keep it on your PC and do the clean up prior to installing the next release.0 -
Install went well.
This does not seem to fix the hesitation in N1MM's use of Winkey. Sending CW from N1MM still has some gaps.
Kevin K4VD0 -
Since this problem has been solved, I am closing this topic.0
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
