Flex 6700 Limiting XVTR output into DEMI 2MLDPA
John - K3MA
Is there a way to set the 144 Mhz power output limit on the Flex 6700 coming out of the XVTR port so that this maximum output can not be exceeded regardless of profile settings or RF Power slider movement? I know when a transverter is setup there is a Dbm level that can be set to limit the drive into the transverter but that selection is not available when not using a transverter.
- 692 The Flea Market
- 119 Aurora
