Hardware revision to Flex 6500
Paul M
I have been looking at the used 6500's that have been on the market lately and would like to know if there has been a significant hardware revision since it was first shipped. Most of the units I have seen are early 2014 to late 2014. Is there a reason to buy a newer unit or is the hardware the same as being shipped today?
Not an expert by any stretch, but my understanding is that the actual hardware has remained the same -- only the firmware has changed significantly :-)
Adding to Donald's comments that the h/w seems to be close to the early release. In the official response to similar question:
https://community.flexradio.com/flexradio/topics/bit-the-bullet-and-purchased-a-used-6500-a-2013-mod...
Tim said there are "no required updates" to the h/w. My interpretation is the firmware/software runs "the same or substantially the same" on the complete 6500 line. In the s/w release notes there have been no exceptions as to h/w vintage.
A slightly different twist, the h/w is fixed without an upgrade path:
https://community.flexradio.com/flexradio/topics/hardware_upgrade_capability_for_6000_series
Not unexpected, as the firmware IS the update. After using a 6500 for a year now it seems the h/w problems are nonexistent and it's up to the s/w and firmware for new features or bug fixes.
HNY
Tim - k3Tim/6
There was a hardware change I believe mid 2014 ... something called the PIN or something like that. It required the unit be returned. The unit I bought recently was made in early 2014 (week 11) but didn't ship to the first owner until August and it had the PIN mod done before it shipped.
Hi Gary,
If you are referring to the PEN update, it only applied to 6700s and then only some of them. I have the details on my web page:
http://www.nn4zz.com/FLEX6700.htm
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
SSDR / DAX / CAT/ 6700 - V 1.10.8
Win10
as far i knot PEN update on 6700 was adding 2 tantalum capacitor on PCB
There was a small update on some early 6300's that dealt with Audio grounding/balance issues at the 8-pin foster mike connector. There was a small hardware update on the 6700 to provide additional cooling and performance for future high processing applications. There were some early changes to some early-run Maestro's. Those are the only hardware updates I remember for the past four years. I don't recall any changes done on the 6500, which is what I own. The only hardware problems I have had with it were self-inflicted... lightning damage because I foolishly left the antenna connected on the wrong day!0
- 409 Community Topics
- 705 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
