60m no TX
HI All
We just been given access to 60m here in EI I have file EU02 Loaded on my 6500 but I can not TX anywhere on the 60m band ???
What do I need to do to enable it,
Trevor
EI2GLB
  • Chris DL5NAM
    Chris DL5NAM Member ✭✭✭
    edited April 2020
    What SSDR version you using? Normally 1.10 beta should fix it. (i thing it's EU00)
    73 Chris
  • Steve G1XOW
    Steve G1XOW Member ✭✭
    edited May 2020
    Trevor,
    EU-02 is fine. At the moment there are no channel markers so there's a bit of guesswork involved. Try just sliding the slice tune passband highlight up and down the whole 60m band and you will see the TX ready/not ready indicator (bottom right) and also the tune button changing as you get to a TX-able segment.
    73 de Steve G1XOW
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    Also, check that your tx bandwidth is not too wide. It cannot be more than 2.7 KHz for SSB on that band.
  • David Decoons, wo2x
    You may need a TURF file from your dealer to enable the new bands. Contact your EU dealer and they can assist.
    The TURF file is specific to the radio serial number and is used to set the bandplan for the region.
    If you have the correct TURF file then see this thread for more info.https://community.flexradio.com/flexradio/topics/60m-out-of-band-tx
  • Chris DL5NAM
    edited December 2016
    Dave, no - it's still included since SSDR 1.10 beta version. Work in hole Europe for 60m.
    If any use in EU not this beta version - he need a special TURF - but not from any dealer (they don't have - most of them don't know what a TURF is :-((   - only from FRS direct only
  • Steve G1XOW
    edited May 2020
    Trevor,
    I am pretty certain you wont need this, but, if you do end up needing a new turf file then Klaus is da man. He will need your specific model number and unit serial number bcause I think the turf file is locked by unit serial number. He emailed me a new turf the same working day when I needed one last year. His contact details below :-
    Klaus Lohmann
    SDR-Funktechnik GmbH
    Tel.: (+49) 4751 900501
    klaus@flex-radio.com
    FlexRadio-EU@t-online.de
    info@sdr-funktechnik.de
  • Chris DL5NAM
    edited April 2020
  • Trevor-EI2GLB
    Trevor-EI2GLB Member
    edited January 2017
    Hi Thanks for the replies updating to beta 1.10 has given me some access to 60m but I can not use most of the allocation we were given in EI
    we have been granted 5351.5 to 5366.5 kHz
    and I can only TX on 5354.0 - 5358.0 CW
    not that I plan to do too much on 60m but I would like to do some JT65 but I can't TX on the part of the band that has activity on it,
    Trevor
    EI2GLB
  • Trevor-EI2GLB
    edited January 2017
    Do I go ahead and log this as a problem to get it resolved ???
    Usually I get a response here that solves the few issues I have had but its gone very quiet in here
    Trevor
    EI2GLB
  • Ed_NZ1Q
    Ed_NZ1Q Member ✭✭
    edited March 2017
    Trevor, did you solve this problem or find a solution somewhere else?
    I'm running into the same problem - only cw will work (TX ready), no other mode will show TX ready on any channel even by sweeping with USB bandwidth set to less than 2.8 kHz.
    SSDR is 1.10.15.43, location is US, rig is 6500
    Ed
  • Stan VA7NF
    Stan VA7NF Member ✭✭✭
    edited February 2017
    Ed, the most common cause of Tx remaining grey is out-of-band.  If carrier + transmit bandwidth exceeds upper frequency (or carrier - lower sideband for the lower) then no Tx.
  • Ed_NZ1Q
    Ed_NZ1Q Member ✭✭
    edited March 2017
    Thanks Stan.  I agree, any hint of out of band (channel in this case) causes the problem.  So I have now stumbled across the source of my problem.
    From everything written so far, it was not made clear what is required.  I had been narrowing the bandwidth in the mode selection on the slice, e.g. using less than 3 kHz, something like 2.9 or 2.7, etc.  This did not work - still no TX.
    Then as I was trying anything else I could, I found that in the "Phone" panel on the right column, the Highcut was set to 3100 !  Reducing this to 3000 or less solved the problem.
    Looks like I am up and running.  Too bad no one suggested checking the low cut - high cut settings, which is the transmit bandwidth = only referring to bandwidth, which I may have mistakenly interpreted as the BW setting in the slice receiver.
    Hope this helps others, but thanks for your reply.
    P.S. the receive BW in the slice receiver seems to be happy with any "receive" BW setting, i.e. 4kHz.
    Ed  -  NZ1Q
  • Trevor-EI2GLB
    edited June 2019
    This is still an issue for me, does Flex bother to fix issues anymore??
  • Jon_EA2W
    Jon_EA2W Member ✭✭
    edited June 2019
    Hi Trevor,
    I´m suffering the same, purchased the radio in UK and have Region EU02. The radio only TX from 5.354 to 5.358 and from 5.362 to 5.374,5. Band allocation here in Spain is 5.351,5 - 5.366,5 kHz.
    Anyone knows how to get this fixed? Is a TURF file from another EU region needed?
    Thank you,
    Jon, EA2OT
  • Dudley  WA5QPZ
    Dudley WA5QPZ Member ✭✭✭
    edited March 2020
    Jon,
    If you purchased the radio originally from distributor,  go back to them for the correct Turf,   or create a HelpDesk ticket ,    http://helpdesk.flexradio.com     ,  explain what you need.
    Dudley,
    WA5QPZ
  • Eric-KE5DTO
    edited June 2019
    Jon,
    What version of SmartSDR are you using? The current band definition for the EU02 has 11 different sections in the 60m band.  If this is no longer current (as I know much of the 60m landscape has changed in the last 12-18 months in the EU), please let us know and we will get this updated.
  • Jon_EA2W
    Jon_EA2W Member ✭✭
    edited June 2019
    Hi Eric,
    The version is 2.5.1. I don´t know to which countries the region EU02 applies.
    Anyway, I opened a helpdesk ticket explaining the situation and received an answer very fast (thank you Flex!). Flex sent me a Turf file corresponding to Region EU12 which is the correct one for Spain. Now all the allowed bands in EA are operable.
    Best regards
    Jon
  • Jon_EA2W
    Jon_EA2W Member ✭✭
    edited June 2019
    Thank you Dudley!
    That´s exactly what I did and received a very fast answer from Flex. Now my radio is transmiting in the correct band allocation.
    Jon, EA2OT
  • Dudley  WA5QPZ
    edited June 2019
    Glad it’s working for you now! Happy DX’n !
  • Trevor-EI2GLB
    edited November 2019
    So I need to upgrade to Ver 2 to be able to use my radio on the frequencies I am allocated to use???
  • Nick RN3KK
    Nick RN3KK Member ✭✭
    edited December 2019
    Maybe my mods helpful any amateurs using 60m, 11m, 100m and other bands, where flex-6xxx device not work on tx, or work only with MARS. https://youtu.be/28rLz2FACBE
