Maestro Battery Indicator
W3EX -- Tom
W3EX -- Tom Member
edited October 2019 in FLEX-6000 Signature Series
My Maestro has a battery indicator on it but it seems to indicate full charge all the times. Is it suppose to indicate the relative charge of the battery or just that it is present.
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited January 2017
    It does NOT indicate charge level
  • W3EX -- Tom
    W3EX -- Tom Member
    edited January 2017
    Thanks. I was afraid of that.
  • Mack
    Mack Member ✭✭✭
    edited October 2019
    Just that the battery is present. Maestro has no way of knowing the size battery that is plugged in.
  • Jay Nation
    Jay Nation Member ✭✭
    edited December 2016
    Some batteries have charge level indicators, built in. (Polanfo) Too bad you can't see them once the cover is snapped back into place.image
     SDRgadgets
    73, Jay - NO5J
  • Ernest - W4EG
    Ernest - W4EG Member ✭✭
    Jay,
    I am considering ordering a another  battery cover and making a slit to see the battery indicator; on the back of the Maestro.
    BTW, I am also using Polanfo batteries, I like the size and weight: You could almost insert two of them inside the Maestro. And the price are more affordable than the  Mogix.I replaced.
