Tutorial: How to create and compile a batch file for SmartSDR and additional programs
DH2ID
DH2ID Member ✭✭✭
edited August 2019 in New Ideas
I wanted to create a batch file to start CAT and DAX, SmartSDR with some addidional programs
as I have encountered problems with CAT in the new version if started from the Windows autostart folder.
To run smoothly the batch file has to
1. Start CAT and DAX minimized
2. Start the programs in the correct order
3. Be compiled into an executable program to be started from the desktop or start menue.
This is the batch file I adapted from John K3MA's batch:
____________________________________________________________________________
@echo off
cd C:Program FilesFlexRadio SystemsSmartSDRDAX
start DAX.lnk
cd C:Program FilesFlexRadio SystemsSmartSDRSmartSDR CAT
start Cat.lnk
cd C:Program Files (x86)MiniDeluxe
start MiniDeluxe.exe
cd C:Program Files (x86)Ham Radio Deluxe
start HRDLogbook.exe
cd C:Program Files (x86)FRStack
start FRStack.lnk
cd C:Program Files (x86)HamAppsJTAlert
start JTAlert.exe /wsjtx
start SmartSDR.exe --serial=XXXX-XXXX-XXXX-XXXX
exit
I created and used links for some programs to start them minimized.
The program I used to compile the batch into a 64bit EXE file is here:
http://www.f2ko.de/en/b2e.php
I use the portable 64bit version, as I don't want to install the program. Under "Programmeinstellungen" or "program settings" you can choose English language.
Under "Options" you can tick "Invisible application" and "Architecture" 32 or 64bit
for your 32 or 64bit OS. Great program, free, and without any viruses.
All this works under Windows7 64bit. I can't test it under Windows10 as I have no
computer running that OS, but it should run also.
Please tell me about any ideas you have concerning batch file improvements and
if you found any problems with Windows 10.
BTW I found that with SSDR version 1.10.8.30 FlexVSP now starts in the background
even if you don't have CAT started from the autostart folder.
I use the Fujitsu serial port viewer and terminal program to view and control my COM ports.
0 votes
In Review · Last Updated
  • LarryF
    LarryF Member ✭✭
    edited August 2019
    Hi Alex,
    Thank you very much for the post.  Brings me back to my old Dos Days and bat files to control programs and  create Menus.  Downloaded program and will be testing it soon.  Will let you know how it works
    Larry ke2yc
  • rfoust
    rfoust Member ✭✭
    edited March 2017
    Nice script, didn't know about the --Serial parameter on smartsdr.exe.  If you're looking for a way to control the 6x00 from a script, I wrote a Powershell module for it.
    https://github.com/rfoust/FlexModule
    -Robbie
  • DH2ID
    DH2ID Member ✭✭✭
    edited December 2016
    I'll look up and try your powershell script, Robbie. Sonds vy interesting!
    Alex - DH2ID
  • Tim Lacy
    Tim Lacy Member
    edited May 2019
    A couple of thoughts from a (don't tell anyone) 20-year Microsoft veteran:
    First, I don't mean any disrespect, at all.  There is valuable stuff in your post.  In addition to all the exe's you start, I also launch DDUtil and a few others.  Your script is terrific for that.
    1)  I don't see a need to create lnk files.  Just use start /MIN, should be fine if that's the goal. I wrote a lot of CMD files to manage processes when I worked on Cosmos, the backend for Bing.  When you need to delete 200 million files via command line, you need to spawn a lot of threads (actually, you just flag them as discarded and let the garbage collector grab them, but it still takes a while)
    2)  I'd suggest - strongly - to move to powershell.  Much more control, direct access to .net API stuff, self-documenting, easy to turn into loadable modules, etc.
    3)  It's... how to say it?  Why create an EXE from your script?  What advantage is there? I've looked into it a few times, and could never make the case that it should be done.  Just increases the maintenance overhead.
    I'd be happy to talk further about this; automation is basically my career.
    -T
    K7GRR
  • DH2ID
    DH2ID Member ✭✭✭
    Hi Tim, thank you for your info.
    @1) I'll try that
    @2) Too complicated for me, I need an easy solution
    @3) I start everything from the Windows Start menue. The link to the .exe file fits there.
    I tried powershell and find it interesting, but why should i use it to start SmartSDR and just a few programs? There might be a beauty to it, but that surely lies in the eyes of the beholder :-)
    73, Alex - DH2ID
  • Tim Lacy
    Tim Lacy Member
    True - the best solution is whatever works for you :-)
    -T
  • Jay Nation
    Jay Nation Member ✭✭
    I did the same with an ever evolving AutoIt script. Which works well until the spelling of the full paths to the executables change.
     SDRgadgets
    73, Jay - NO5J
  • Andy - KU7T
    Andy - KU7T Member ✭✭
    edited September 2018
    I played with this tonight and wanted to post the finished script, that starts CAT, DAX, SDR, DDUtil, SDRBridge, CWSkimmer, RBN, Wintelnetx, N1MM+. This gets me up and running in 1 min...  Off course some of these are optional, but thought that a few of you may be interested.
    rem DAX
    pushd "C:Program FilesFlexRadio SystemsSmartSDR v1.10.16DAX"
    start "" Dax.exe /MIN
    popd
    timeout /t 5
    rem CAT
    pushd "C:Program FilesFlexRadio SystemsSmartSDR v1.10.16SmartSDR CAT"
    start "" Cat.exe /MIN
    popd
    timeout /t 5
    rem Flex radio start
    pushd "C:Program FilesFlexRadio SystemsSmartSDR v1.10.16""
    start "" "SmartSDR.exe"  --serial=2017-5331-6700-1665
    popd
    timeout /t 5
    rem DDUtil
    pushd C:DDUtil_V3
    start "" DDUtil_V3.exe
    popd
    timeout /t 10
    rem sdr bridge to launch skimmer for local band spots
    pushd "C:Program Files (x86)W2RFSDR-Bridge""
    start "" "SdrBridge.exe" /MIN
    popd
    timeout /t 5
    rem RBN to post local band spots
    pushd "C:Program Files (x86)RBN"
    start "" rbn_aggregator_v4.4.exe /MIN
    popd
    rem wintelnetX to merge public node with local band spots
    pushd "C:Program Files (x86)WinTelnetX"
    start "" wintelnetx.exe iniMY_skimmer_plus_node_to_logger.ini -start
    popd
    rem N1MM+
    pushd "C:Program Files (x86)N1MM Logger+"
    start "" N1MMLogger.net.exe
    popd
    Andy
  • Mark WS7M
    Mark WS7M Member ✭✭
    edited June 2017
    You know Jay... Had you sent me that Hex beam in your garage like you promised you would have had much more time to evolve that AutoIt script into something totally useful!
    Just sayin!
  • Andy - KU7T
    I have an updated to the script. It launches everything on my box now and I thought I would share it here again. Use and edit to your hearts content. The below launches all this in about 1 minute (in this order):
    DXLAB, Green Heron Server, DAX, CAT, RBN, W2, PstRotatorAz, Voaprop, Wintelnetx, DDUtil, SliceMaster, Green Heron Client, SmartSDR, N1MM+
    setlocal
    set SmartSDRPath=C:Program FilesFlexRadio SystemsSmartSDR v2.2.8
    pushd "C:DXLabLauncher"
    start "" "DXLabLauncher.exe"
    popd
    pushd "C:Program Files (x86)Green Heron EngineeringGH Everyware Server"
    start "" "GH Everyware Server.exe"
    popd
    pushd "%SmartSDRPath%DAX"
    popd
    pushd "%SmartSDRPath%SmartSDR CAT"
    popd
    pushd "C:Program Files (x86)Aggregator"
    start "" rbn_aggregator_v4.4 /MIN
    popd
    pushd "C:Program Files (x86)ElecraftW2 Meter"
    start "" W2.exe
    popd
    pushd "C:Program Files (x86)PstRotatorAz"
    start "" "PstRotatorAz.exe"
    popd
    pushd "C:Program Files (x86)VOAProp"
    start "" "VOAProp.exe"
    popd
    pushd "C:Program Files (x86)wintelnetx_4_22"
    start "" wintelnetx.exe -start iniMySkimmer_plus_W9PA_to_localhost23.ini
    popd
    pushd C:DDUtil_V3
    popd
    pushd "C:Program Files (x86)slice-master-6000-v0.10.4"
    start "" "slice-master.exe"
    popd
    pause Wait until N1MM-DXKeeper gateway and Green Heron Server are started
    pushd "C:Program Files (x86)Green Heron EngineeringGH Everyware Client"
    start "" "GH Everyware Client.exe"
    popd
    rem uncomment, if you want to start SmartSDR and not run the 6600M
    rem pushd "%SmartSDRPath%""
    rem start "" "SmartSDR.exe"  --serial=xxxx-xxxx-xxxx-xxxx
    rem popd
    start "" "N1MMLogger.net.exe"
    popd
    endlocal
