Missing features / possible improvements for next release
DH1RK
DH1RK Member ✭✭
edited November 2016 in SmartSDR for Windows
Hello,
here I want to list some features of the SmartSDR which I´m really missing and doesn´t see anything mentioned about a possible fix / feature enhancement:
Maestro improvements:
- Add handling for TNF
- RIT / XIT displaying
For SmartSDR / Maestro:
- Adding 2nd level for startup for Network selection, Software Version => remove of useless HMI interaction at startup
- Standard width of TNF shall be set for preset e.g. 500Hz, deep ... to have it directly available and to have easier handling due to it bigger size
- FIFO memory for frequency storage (e.g. 10freq buffer, per band) => using Lock A + B for save and recall in conjunction with VFO to go through the list
- No limitation of external PTT, if DAX channels are used (no manual keying possible)
- Minimum 1 stereo DAX channel (e.g. Ch.1 for L/R support)
- ANF with better performance like on Icom, ringing in SSB mode
- Using button "Step B" for decreasing the Tuning Step, if only one VFO is used
Kind regards,
Ruediger, DH1RK
