Maestro locks up - repeatable problem using verision 1.9.13.23
K7NXT
K7NXT Member
edited November 2016 in FLEX-6000 Signature Series
My Maestro will not return to the original band once I select another band from the menu and then try to select the original band again. Only solution I have found is to cycle power on the Maestro.
This is repeatable. My Software version is 1.9.13.23.
Example, original band is 40M. Then switch to 20M. Then switch back. The display still shows 20M frequencies but the reception is not working.  This happens without transmitting.
I don't recall ever having this problem with earlier software versions.
I have a 6500 and use it via wifi.
Pardon me if this is a known problem.  I didn't see it in the database.
Thanks for your help.  William  K7NXT
