Quick record with N1MM
Mike NN9DD
Mike NN9DD Member ✭✭
Can I use the ctrl + shift+ F key to quick record for Macro. I hope so and if I can what is the set up I can't get it to work. The other options is record in Audacity and then place in directory which is more work Please let me know which way to go Mike N9DFD
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    I have successfully used the recording feature in N1MM Plus...
    The N1MM Plus Manual has information on page 166
    Download from:
    http://n1mm.hamdocs.com/tiki-download_file.php?fileId=3095
    You must tell it that your recording device is DAX MIC Stream if you want to record from your rig's mic.
    You must also activate DAX MIC Stream in the DAX Control panel.
    Also...click the box in the Configure>Audio tab that "Output Device is an internal Radio codec."
    I am not at the rig right now, so I don't have any more information, but this may get you over the ****.
    Ken - NM9P
  • Mike NN9DD
    edited October 2019
    Thanks Ken I will back to the shack and check it out. I have and no luck but the radio codec I have kind of ignored so hopefully that will do it Mike
  • ctate243
    ctate243 Member ✭✭
    edited October 2019
    OK let me give this a shot
    .. In DAX panel..
    -enable TX stream.
    -in the p/cw panel in SSDR turn on dax button, TX stream should turn blue
    -Enable Mic stream
    In N1MM  select
    config > logger + audio setup
     on the MESSAGE RECORDING tab select DAX Mic audio in the pulldown
    in the PLAYBACK tab select DAX Audio TX as the playback device.
    you can experiment with the internal radio codec checkbox.. seems to work without it.
    *please note when I tested this a few minutes ago I had to hit the footswitch to get the recordings to record..  not sure whats up with that.. will investigate.. but anyway that should get you rolling.
    ~Chris
  • ctate243
    ctate243 Member ✭✭
    edited October 2016
    so this last little complication  is cntl-shift-F1 footswitch > message > F1  again this will get you rolling while I play around with this a bit more to figure out why.
  • Mike NN9DD
    edited December 2016
    You were right on. I found that I did not enable the mic stream so there was nothing to record. Once I enabled that off we went. I have the directories set up and the recorded separate greeting for each op as a test. Just need to get ops to record in their voice Thanks Chris Mike N9DFD
  • ctate243
    ctate243 Member ✭✭
    edited October 2016
    No problem sorry the instructions were a little choppy my stepson was tugging on my shirt to take him to soccer practice.  glad you are up and running.  GL in the test this weekend.  Ill probably do a single band for SSB from K6LRG.. have a limited availability.  have fun
  • Mike NN9DD
    Thanks. Does the VOX need to be on. I hate running vox if you know a way to trigger PTT would be helpful Mike
  • ctate243
    ctate243 Member ✭✭
    edited October 2016
    Footswitch?
  • ctate243
    ctate243 Member ✭✭
    edited October 2016
    Oh sorry I get it.  config  > configure ports......  > select your flex port, select SET and put a check box in the PTT via radio command SSB mode.. that should work
  • ctate243
    ctate243 Member ✭✭
    edited April 2017
    BTW, your monitor audio will be raw and not reflective of your actual tx audio (compression, etc.) but is functional to let you know N1MM is firing away.  I will turn you back over to NM9P and his videos for checking tx audio in FDX.  Ken over to you on the next go round... back to net. ;-).
  • ctate243
    ctate243 Member ✭✭
    edited October 2016
    no vox needed. you may however want to use it while recording voice messages in N1MM and turn it off afterwards.
  • Mike NN9DD
    edited October 2019
    That was it Thanks Chris
  • ctate243
    ctate243 Member ✭✭
    edited April 2017
    Not a problem Mike.  Good luck in the contest.
