New to rtty and dm780 settup for xmit.
Jerry Wilk
I am using a Flex 6300 with DM780 for winkeyer and PSK modes with no problem but never used rtty modes. Can receive rtty signals in USB afsk mode on 20 m. Trying to figure out the correct way to set up DM780 to xmit rtty signals correctly? All help appreciated.
If your psk is working just switch DM780 to RTTY as it sounds like you have and let it rip
Should work if psk was working
N9DFD0 -
Flex to RTTY setting, DM780 RTTY-45(AFSK), Reverse, same CAT/DAX settings you use for PSK, Save as a profile and you're good to go. You will need to select "Reverse" each time you start DM780. I haven't found a way to get it to save that parameter.0
Thanks for your replies. I am a little confused as to the center frequency setting of 2210 and how it relates to the transmit frequency. When I set DM780 cursor to the incoming rtty signal (i.e. like psk31) am I transmitting directly to that incoming signal or some offset?0
I figured it out last night as how to use the center frequency set at 2210.0
- 693 The Flea Market
