Flex6700 Transverter Frequency Reads Incorrect with 1.9.13.87 Display Bug Bad Math !!!
mikeatthebeach .
mikeatthebeach . Member ✭✭
My new Flex670 with 1.9.13.87 when setting RF to 432.000MHZ and a 144MHz IF
the Spectrum Display/Waterfall shows the LO Frequency 288MHz not 144MHz
Definite Bug will not work for my Microwave Frequencies !!
  • W0DHB
    W0DHB Member ✭✭
    edited November 2016
    I confirm that here Mike, you should submit a ticket. Dave W0DHB
  • mikeatthebeach .
    edited October 2016
    Not sure how to submit a ticket
    Their Transverter setting XVTR mode should indicate either High Side or Low Side LO as well
    Maybe FRS does not know how Mixers work since none exist in the Flex6700
  • Marc Lalonde
    Marc Lalonde Member ✭✭
    edited October 2016
    HI  here it display right frequency ?  have 1.9.13
    RF = 432   IF = 28mhz
    and software calculate 404 as IF
    VE2OLM
  • mikeatthebeach .
    edited October 2016
    Have Transverters at different Microwave Bands RF at 10.368GHz Transverter with IF = 144MHz by DB6DT
    another transverter at
    RF at 432MHz Transverter at 1296MHz with IF =144MHz
    RF at 1296MHz with IF = 144MHz
    Calculation & Display incorrect with 144MHz IF frequencies
    (Edited)
  • Marc Lalonde
    edited October 2016
    HI  whit 10G one whit 144 IF
    i hear the packet a 144.390  and dispaly 10.000.390 so seem good
    sorry no local 10G signal for the test  whit the real Transverter
  • Dan Hammill
    Dan Hammill Member
    edited October 2016
    I submitted a ticket for this same problem a few months ago for SmartSDR 1.6.21 when I tried to set up my VHF & UHF transverters.  At the time, I was told that I was the only person reporting this problem.  After going through several factory resets and database reconstructions at Tim's behest, there was no change.  Afterwards, Tim informed me that it had been recorded as a bug.  That was the last I heard of it.  Hopefully, now that I'm not alone, it will receive more attention.  Dan, KB5MY
  • Dan Hammill
    Dan Hammill Member
    edited October 2016
    Sorry...the resets, etc. were at Dudley's behest.  My help ticket was #13751, and the issue was logged as defect number 2563 on 8 July 2016.  Dan, KB5MY
  • mikeatthebeach .
    edited October 2016
    Still a problem here Display is incorrect image
  • Dan Hammill
    Dan Hammill Member
    edited October 2016
    Anyone experiencing this problem should submit a help desk ticket and reference defect number 2563.  I believe there is info on submitting help tickets on Flex's website - that's where I went to find out how.  Dan, KB5MY
  • mikeatthebeach .
    edited October 2016
    Been more complaints about this bug
  • Marc Lalonde
    edited October 2016
    at first it put me to on 9856....   but if put VFO on 10.000.240 it hear the signal
    so i think it put by default the VFO on the IF frequency , but conversion was still good
    did you try to tune to know signal source
  • mikeatthebeach .
    edited October 2016
    With  RF set to 10368.000MHz and IF set to 144MHz
    The Display is at LO Frequency and WILL NOT ALLOW YOU TO GO TO 10368MHZ
    It is still a problem !
  • mikeatthebeach .
    edited October 2016
    For 10GHz weak signals these are the frequencies
    For Canada & USA Region 2 Frequency is 10.3681GHz SSB Weak Signal Calling
    Frequency - 10368.1MHz
    Guess you have no Microwave SSB Weak Signal Equipment there !
  • mikeatthebeach .
    edited October 2016
  • Marc Lalonde
    edited October 2016
    Strange here i able to put VFO on desired frequency ,  just like it was on HF
  • mikeatthebeach .
    edited October 2016
    Guess you lucky _ Running Windows 10 32 bit here
  • Marc Lalonde
    edited October 2016
    ok win 7 PRO here  ,but first tine i set the transverter i have to type VFO frequency by hand since it initially go to LO frequency , but one put on right frequency it worker fine  ,hope Felx find the issue and fix it  need more HAM on microwave  ,closes HAM that do microwave was >300 KM away ...
    on my side i use  Graham VK3XDK  design  for 3.4 / 5.7 and 10G  and  Demi for 432  , 1296
  • Simon Lewis
    Simon Lewis Member ✭✭
    edited July 2017
    on first setup it shows the RF freq as IF - I re-enter the RF freq and its all fine - def still a bug and has been since a long while
    edited March 2017
    As previously noted, this issue is already in our bug tracker as defect #2563.
