Anyone else notice their 6XXX not changing bands ?
N9VC
Hi,
Wondering if anyone else noticed this. Four times
now, I have chose a frequency from memory and then
went to another band after operating a while. I
first went to 80 meters with the memory button. The
radio was 80 meters for about 5 hours. Then I used
the band button to go from 80 to 160. The screen
shows I am on 160 but the radio stayed on 80. Then
if I choose the band from memory, then it will go to
the correct band.
Example I was then on 160 listening to Newsline on
1860 AM, went to the gen band by the button to 900
KHz, then pressed the 80 meter button. Everything
changed and could see CW signals around 3555 KHz.
But the audio from 160 was coming through.
But this does not happen every time. So not sure if
I should reload the software or others have noticed
this also.
Version is 1.9.13.89
73, Jim N9VC
the correct band.
this also.
73, Jim N9VC
I have started noticing the same thing on the rare occasion. Started doing it with the last couple software updates.0
A defect report on this issue has been logged by FRS Engineering.0
Thanks, Mark.
73, Jim N9VC
- 407 Community Topics
- 705 The Flea Market
- 205 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 983 Genius Products
- 328 Shack Infrastructure
- 233 Networking
