Cw skimmer with 6300
Pat Hoppe
Member ✭
I have the latest version of the SDR Bridge and the CW Skimmer. When setting up the skimmer, which radio should I select? On the settings screen for the radio, there is a LO freq box. What frequency is entered there. I had things working for a moment but then it all went bad
Any direction would be great.
Pat WW9R
Pat WW9R
3
Pat, here is my setup for Skimmer&bridge:
LO Frequency is put there by SDR bridge.
Be sure to tune a few times using different frequencies and bands until bridge
and skimmer are synchronized. Now if you click twice on a CW Skimmer
waterfall signal, exactly this signal will be tuned to in the SmartSDR slice.
This shows LO frequency = SDR Bridge frequency = SmartSDR slice frequency.
Notice: I intentionally use a 48kHz stream for CW, you can set this in CW Skimmer, but
you must be sure to set the same stream width in DAX control:
73, Alex - DH2ID1 -
I use the same settings except i use 96 khz sampling rate and also use port 7320 if i slim two clices at once.1
- 685 The Flea Market
