Adjacent Station Interference v1.9
I have both a 5000 and a 6500 and notice no difference in the out of band rejection. Could be you are confusing in-band stuff with out of band stuff. If there is "bleed over" from an adjacent station due to non-linearity, etc. it is a "valid" in band frequency and you will here it.
Jim, K6QE
I assume you know, with this release one may adjust sharpness of filters, I don't know if default changed or not from prior release.
Lew
N4CO0 -
David, I was operating last weekend for the first time with 1.9.. And did end up asking myself if something was a little different (hearing stations 1-2 KHz away, when I didn't remember that being an issue before). I haven't played with the new filter options yet, so it could very well be it. Maybe the defaults are less sharp.0
Sounds like were sensing the same thing. I will have to try the filter out of the auto mode to sharp (the next and last notch up in the slider).
Who said anything about out of band?
if you haven't changed them already, then I found the default filter settings to be less than ideal for DX/contest working (too soft on the slope). The first thing I did was to set them back to the sharp end of the scale and manual not auto.0
I am trying the manual sharp now and the behavior seems be more like I recall. It would be interesting to see the actual slopes for each setting look like and what network bandwidth differences there are between them.
When running the RTTY contest and using MMTTY and 2Tone I could tell by looking at the signal displays for these apps how the filter was changing just by looking at the noise floor. The low latency wide filter was a nice bell curve while the high latency sharp filter really displayed sharp skirts.
I don't know how latency affects anything but the general shape of the filter became pretty obvious.0 -
The wider the skirts the lower the latency In fact, the low latency shapes were added to assist contesting with faster turn around times by spending less time in the fitter system you get less sharp filters.0
faster turns are nice on CW, but of no use in SSB contests if you are going to get clobbered by S9+40 sigs over 5kHz away, as is often the case in the bigger EU contests.
Which is why the filters are adjustable by MODE - so for SSB they can remain Brick Wall Sharp0
I wonder how the auto setting logic works. It would seem for SSB it would default sharp keeping the Flex brick wall standard in place. But maybe the auto does some sensing and adjusts as necessary. In the limited comparison testing of low latency to sharp I didn't perceive and latency difference but I am not a contester so I probably don't know what to pay attention to to notice.
Thank you everyone for pointing out the filters.
Filters on CW contesting. The slightly wider slope is great; the broad setting not so.
On a cluttered band, or with heavy noise/weak signals I move the filters in to under 200Hz. BUT: With the old filters a station answering slightly off frequency would not be heard, at all; only clue was a signal on the panadapter. Now that signal is just audible, enough to catch a call.
Then there were the days with a couple of crystals. Someone answering could be as much as 25Khz away, and I'm now complaining about 200Hz off frequency; times have changed.
Calling CQ and then tuning a big dial above and below your Xtal frequency was a great thrill when you heard a weak signal pounding out your call 20 kHz away. Always gave me goosebumps. T/R Latency was measured by how fast I could flip the knifeblade antenna switch. haha ...0
- 688 The Flea Market
- 105 Aurora
