Help with FRStacks on 6700
Gary
Gary Member
edited February 2018 in SmartSDR for Windows
Installed FRStacks program - worked fine ... a few days later it wouldn't start up. I double click its icon and I see the little whirl symbol for a second or so and then nothing. I've uninstalled and reinstalled to no avail. I've no clue where to go for help on this. I know where to download but there's no indication of where to get help ... this is using a 6700 on a Win10 machine. Running, at that time, 1.9.7
  • Mark_W3II
    Mark_W3II Member ✭✭✭
    Delete your local FRStack MKCM_Software_LLC settings folder. This will not delete your memories; only your settings like hotkey assignments.This is located at "C:Users<yourusername>AppDataLocalMKCM_Software_LLC". "<yourusername>" should be replaced with your windows user profile name. Look for it in the c:users directory or run "SET USERPROFILE" in CMD windows to see what your current profile is.
    You can always contact me directly at MKCMSoftware AT gmail.com
  • Gary
    Gary Member
    edited April 2017
    Thanks Mark ... I'll give it a try.
