EXT Bandpass Filters for 6300?
Paul - K6HR
I will be running my 6300 and 5000 in an SO2R configuration with an SPE 1K-FA amplifier. It was suggested I consider bandpass filters for enhanced isolation between radios. I see I can control these filters easily, so now I'm looking for advice from any Flexers that use them. I'm currently considering the Array Solutions AS-419 and open to suggestions and advice. What type of results should I expect, etc.
I use two of these auto switched by the Flex. https://www.arraysolutions.com/filters/bpf-hpf/filtermax-5 Works great at legal limit on two separate yagis on different towers. Mack W4AX Alpha Tester0
Maximum allowable continuous power: 200 W
