Setting up for LAN... total rookie
Andrew O'Brien
Member ✭✭✭
So this may seem a ridiculous set of questions and some may ask for my extra class license to be rescinded as a result of stupidity ... but as the weekend arrives I may try "messing" with a home network so that the 6300 can be on a LAN and discoverable with iOS 10 devices. I have had numerous PCs over the years but never actually got around to setting up a home network where several PCs shared a printer, etc. Way back in early Windows days when home networking was becoming easier, I tried once but never really got beyond the basics of having several PCs share one internet connection.
Let me start with... is ALL that is needed is for the Flex to be plugged in to a spare port on the cable modem/router or do I have to formally establish a home network? At home we have two desktops PCs and three laptops , one is connected to the router via Ethernet, the rest via Wifi.
I'll stop there and save other questions for later.
You've just described your home network! Plug the flex into a port on the router! Add a wifi printer and you're done! W2AIV0
Yep, just plug it into the LAN side of your router. The flex will broadcast its presence and the app will pick it up.0
Yep. Anything connected to your router is potentially part of the home network. For some devices, you may need to define what Workgroup or Homegroup they are part of, or define their file sharing properties in the network properties, but that is really simple. If you haven't changed any of them, they are probably already on the default Workgroup. As far as using the Flex from other computers or iOS devices on your LAN, you are good to go! Install the software on the device and go for it. Removing from OUTSIDE your LAN is a little more complicated, but not much. And it will get a lot easier when V.2.0 is released.0
If you do not feel comfortable with that level of system administration you can always simply plug your computer directly into the radio.
Another "Auto-Corrupt" error........ "REMOTING from outside your LAN.......". Not REMOVING.....1
- 715 The Flea Market
- 218 SmartSDR+
- 469 SmartSDR for Mac
- 130 Aurora
- 994 Genius Products
- 363 Tuner Genius XL
- 138 Antenna Genius
- 331 Shack Infrastructure
- 235 Networking
