Flex 6300 transverter usage - memory channels and step values
IW7DMH, Enzo
IW7DMH, Enzo Member ✭✭
edited March 2017 in SmartSDR for Windows
Hello,
after having installed a VHF transveter I found that the memory recall function (in Memory Channels menu) doesn't set properly CTCSS values, both Tone Mode and Tone Value.
They are properly stored in the memory record. Probably it is a bug.
I also found that in the step values I can't find the 12500 value (12.5Khz). I find it helpful in FM mode for alfa-repeaters access.
73' Enzo
iw7dmh
    edited March 2017
    I have added your bug report as issue #1422 and your feature request to add a 12.5k tune step as feature request #14023.
