flex 3000. No sound or signal display.
Try reducing the sampling rate of the Firewire card.0
I found on my laptop that if I dont have VAC enabled, I don't get any sound although I do see a waterfall display. Laptop is a HP touchscreen
Do you have powered computer speakers plugged directly into the 3000? If not, you will not get audio from the PC unless you route the output audio to the PC using VAC,0
Thanks for your reply Tim.
Lowering sample rate to 48000 didn’t change anything.
Yes, I do have powered speakers hooked to 3000 but that is not the real issue.
FYI, the setup is as follows:
Flex 3000 s/n 2010-0640 firmware 2137 trx 1710-0057 (35I) PA 1810-0031 (36K)
Dell desktop inspiron 3650 with 8gb ram. Windows 10 home. Intel core i3 at 3.7ghz. 64 bit OS. SIIG 2 port PCIE firewire card. SIIG says the card uses standard windows 10 driver.
Just about everything in the flex is default except the audio sample rate is now set to 48000. Have not installed any VAC yet.
If I start power sdr the program comes up looking normal. When I click START the button changes as its should. All buttons operate. I can drag or click the frequency display on the spectrum display ok. But there is no indication of band noise or signals or waterfall........and no sound.
I have installed and uninstalled the last and next recent version of power sdr with the same results.
sometimes when starting the new system it has said i need a firmware update and each time it seems to download and then start powersdr ok.
The flex still works ok in an old laptop with amd turion 64 and vista and integrated firewire. The problem must be with my setup or firewire card or desktop.
Interesting fact ... if I try to tune ATU into a good load it starts and then stops and says no rf detected.
Help please
Dave
AD1R
This behavior is indicative of the Firewire interface in the PC not properly communicating with the radio hardware. I suspect you are using a Firewire card/interface that is not using a TI chipset.0
I have the same problem with my new Thinkpad P71 and Syba SD-EXPC34-2F TI Chipset 1394a (400Mbps) 2x Ports, 34mm ExpressCard over windows 10.
This expresscard worked fine with my old HP and windows 100 -
I am having the same 3K problem with a Dell Latitude SIIG Firewire Card and Win 10 .. The radio runs with audio for about 2 seconds then stops. Dell is running a duo core Centrino processor If I click stop and start, it starts for 2 seconds then stops. .Firewire card and radio work fine with I plug them into my HP EliteBook 8460P laptop. HP is running a i5 processor Win10
Glad you mentioned you have a Syba TI chipset. I was thinking that might be an issue since SIIG card is VIA chipset. But guess it's something else
Jim NX3Z.
Maybe try changing you audio sample rate?0
Hi everybody,
I just received a new Startech Firewire express card EC13942A2 with VIA chipset and it works fine with my new Thinkpad P71 over windows 10
I tried other sample rates. The express card works fine on another Dell Laptop and a HP both running win 10. Maybe something wrong with dell express card set up corrupted driver maybe0
I’m going to try reinstalling win100
- 417 Community Topics
- 716 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
