Smart sdr ios vpn
Rob Swannell
Want toset up IOS using VPN on ipad , having problems setting up vpn excess with ipad. I have been using softether server software on raspberry pi at my home router. Also I have maestro using the raspberry pi with softether bridge software working through my hotspot on my mobile phone , working with no problem's. I did try the VPN on my iPad with home network using ip address it work. But when trying my ddns id and out my network does not work. I have the softether ports on penalties on router. Any ideas. Rob G3XFA g3xfa@btinternet.com
I assume you are use L2TP on your iPad. Most people do not port forward their router:
UDP port 500
UDP port 1701
UDP port 4500
Jim, K6QE
Still no luck with the VPN connection on ipad0
- 996 Maestro
