Maestro bug? - 1.8.4
mlstutler
mlstutler Member ✭✭
Flex 6300 and Maestro.   Maestro is connected via Wifi.   Occasionally when the version screen appears the Maestro will begin a step 3 of 4 download.   It then seems to boot fine on the version.   I have had it happen about 3 times.   Wondering if this is a tracked issue?
Mike, W8MLS
  • Mal
    Mal Member
    edited April 2019
    I suddenly have the same thing, it takes about 2 seconds then starts normally.
    Mal
  • [Deleted User]
    edited April 2020
    I have had the problem occasionally since I updated. Don't remember if it was there with the previous version.
  • mlstutler
    mlstutler Member ✭✭
    edited July 2018
    I went back and found very similar threads.   Tim had advised that if any had this issue to open a support ticket.   I went ahead and opened a ticket.
  • NX6D Dave
    NX6D Dave Member ✭✭
    edited December 2019
    This is well known. I don't recall if this is considered a bug, but it is considered harmless.
  • mlstutler
    mlstutler Member ✭✭
    edited July 2018
    The fact that it happens intermittently leads me to believe that some condition is happening that the boot up process is triggering the processes for step 3/4.   it may be harmless,  then again maybe one time it will brick the Maestro.
  • Mark G Thomas
    Mark G Thomas Member ✭✭
    edited August 2016
    Mine does this sometimes too. I am guessing it might be a consequence of the protective measures put in place to solve the prior maestro-bricking problem, and will probably be addressed in a future update.
    edited May 2020
    This is a known issue that will be addressed with the next release of SmartSDR for Maestro.
  • k3Tim
    k3Tim Member ✭✭✭
    edited December 2016
    have to ask....
    " will be addressed with the next release of SmartSDR for Maestro"
    and when would that be?
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited August 2016
    Come on TIM. YOU KNOW BETTER. THAN TO ASK THAT QUESTION. When the answer is obviously either SOON or SOMEDAY. Hi Hi.
  • Phil M0VSE
    Phil M0VSE Member ✭✭
    edited September 2016
    On another thread Steve said that 1.9 is targeted for release mid September so I guess then?
    Please note the language in Steve's post - targeted for mid-September.  This is assuming that all of the coding stays on schedule and we do not discover anything in testing that requires significant time to address.
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    Ok..I'll volunteer..what do you need from me to help meet that date?  coffee,  cookies..Patriots tickets....
    Just patience ;-)
