Erratic behavior in SO2DR mode?
Dave
Dave Member ✭✭
edited December 2016 in Third-Party Software
When both pan adapters are active on different bands, 80 and 40 in this case, maestro behaves erratically. The slice on 40 meters will suddenly jump to the 80 meter pan adapter and vice-versa, seemingly triggered by changing the active TX setting. Saving a global SO2R configuration also doesn't work, when I try and load a saved SO2R configuration back in, both pan adapters are set to the same band...
