can't get a response from 2m repeaters
James Madden
with demi transverters properly hooked up, can't get a response from repeaters.
this image show 2 repeaters being received, but i can't get a response when transmitting from either. my antennas are M2 satellite for 2m and 70 cm.
jim0 -
What repeater is on that weird frequency of 146.659.8000
I think he's trying the 146.60 Sea-Tac repeater. 200 Hz error in display or tuning isn't a real problem.0
Thanks George. You are correct. Jim0
Actually i think the repeater frequency is 146.66 mhz0
Yes, .66 - my typo. James, any progress on getting screen shots of your transverter configuration pane? Confirming relays are enabled? Power levels?0
Also, can I ask which radio you have? 6300/6500 with DEMI XVTR or 6700 and DEMI 2M-LDPA?0
Sure. Ive got a 6700 and the demi 2m and 70cm transvertera, their new ones for the 6700.0
Where are the relay configurations located? Thanks. Jim0
Radio setup - transmit tab. (Manual page 105)0
On my transverter configuration (which admittedly is for Kuhne devices on a FRS 6500), In the XVTR pane, I have the RF Frequency set to 70.000MHz for 4m, 144.000MHz for 2m and 432MHz for 70cm. I am not sure about the US 2m frequencies but 145.330 as the starting point seems a little odd to my UK eyes!
I should add hat I can get into repeaters on 2m and 70cm on FM and on D-Star so my configuration certainly works!
This may be a red herring but it just looked wrong to me!
David G4NRT0 -
You have a 6700 that already covers 2m and you are setting up a 2m transverter. That may be your issue.0
Try this experiment:
1. Delete your 2M XVTR profile
2. Set BAND to 10m
3. Set TX and RX ANT to XVTR (I'm assuming you have a common IF configuration. Let me know if otherwise)
4. Set MODE to FM
5. Set FREQ to 30.66MHz (This is your 146.66MHz RF freq - 116MHz L.O. in the DEMI XVTR)
6. Set your offset to 600kHz
7. Set your CTCSS to the appropriate tone
8. Set the OFFSET to (-) .. .Your choices are -,Simplex,+, and REV
See if you can key your repeater and hear it. Alternatively, you can go to SIMPLEX and use a handheld to make sure you are putting out on the right freq.
Once you verify your radio and XVTR are functional and connected properly, you can then go in and create a 2M XVTR profile. I suggest setting the RF FREQ to the Base FREQ in the band (144.0MHz, 432.0MHz etc) then setting the IF to 28MHz. That makes the freq displays easier to deal with.
Good luck!
Greg - K5GJ
Just to prevent someone from making the same dumb mistake I made when setting up repeater use with my transverter:
I didn't really see the offset in the Flex OPT screen as being in MHz, so I entered 600, making the offset 600 MHz. Of course, the repeaters did not respond. While "troubleshooting", I finally noticed that the offset was in MHz--setting it to 0.6 "fixed" my problem. Duh. Operator error.
Larry, W1IZZ
Hi,
I had the same problem and here is what I found. A mistake I made was when
I hit the TUNE button, I was only putting out a carrier. When I hit the MOX button,
then the tone access worked and I brought up the repeater. Maybe that is not
your problem, but it was mine.
73, Jim N9VC
First off, have you made any SIMPLEX contacts on 2m FM yet?
I may be wrong but with a 6700 and a DEMI LDPA, you are NOT using a Transverter. You should NOT be using the XVTR tab in the Setup. It has NOTHING to do with operating the 6700 and the DEMI for 2 meters. 2m is built into the 6700 and does not require a Transverter.
I use a LDPA with my 6700 and other than being a bit off frequency and the fact that there isn't any tone filter, it will work through a repeater. When listening to repeaters, you will hear the tones loud and clear. When I operate the 146.840 repeater, I set the slice to 1465.840.800
VHF Antenna must be connected to the DEMI
BNC connection between DEMI and XVTR port on 6700
You must have a Phono cable between the DEMI and the 6700 to key the amp
I'm assuming all of the above is in check and when you press the PTT the DEMI goes into transmit and you get a carrier output if in FM.
Make sure that when you set up your slice, you select:
SLICE:
Mode must be FM
ANT TX and RX should be XVTR
Select drop down: CTCSS TX
Select drop down: Proper Tone
Offset: Usually .6 Mhz
- or + depending on repeater.
I have to set my RF Power to 100% when driving the DEMI 75w model to get between 55 and 60 watts or so out of it.
Thanks for the thread, I also put 600 in offset field instead of .6...user error once again!0
- 713 The Flea Market
- 210 SmartSDR+
- 466 SmartSDR for Mac
- 128 Aurora
- 991 Genius Products
- 330 Shack Infrastructure
- 234 Networking
