Maestro AF Gain DEFAULTS
Norm - W7CK
Norm - W7CK Member ✭✭
edited November 2017 in Maestro
Every time I press the "A" or "B" to select a panadapter or slice within a panadapter, the AF Gain defaults to 50% and blows me out of the room.
Will this EVER be changed so that it REMEMBERS what the last setting was?  If not, can the default be changed to anything other than 50%?
Norm - W7CK
  • Al K0VM
    Al K0VM Member ✭✭✭
    To be clear, which "A" & "B" are you refering ?  The A &B  that open/close a slice ( next to ANT ) ?  ANd which audio output is in  use, Inter/external Maestro or the radio output ?
    AL, K0VM
