Question on SSDR NB
Burch - K4QXX
Burch - K4QXX ✭✭
edited March 2017 in FLEX-6000 Signature Series
The addition of the WNB has really improved the working conditions at my QTH.  I get a lot of power line noise and the WNB does a pretty good job most of the time.  I also like the fact that it reduces the noise on the panadapter.  Sometimes I turn on the WNB and I still have some noise which the regular NB takes out.  The NB doesn't affect the panadapter but as least it seems to work pretty well taking out the buzz.  My issue is it seems to degrade over time.  I'll turn on the NB and run the slider to the lowest point which still takes out the noise.  If I start tuning around, the NB is still on but it stops working.  If I turn it off and back on, it starts working again but after a short period of time, it's no longer effective.  This doesn't just happen when tuning.  For example, if I am listing to a weak to moderate station, I'll turn on the NB if I have noise.  It will take out the noise but then if another stronger station comes on the same frequency, the NB looses it's affect.  The NB has been like this since before the WNB was introduced.  Does anyone else notice this?  If the NB would stay active, the combination of the WNB and NB at my location would really be nice.  I find myself constantly turning off and back on the NB to "reset" it.
Burch
    Tim - W4TME admin
    edited March 2017
    Good  catch.  It looks like we are not instructing the NB to retrain on the noise after a tune operation.  I have entered this report into our bug tracker as defect #3745 so we can investigate it further.
    In regards to the behavior you see when listening to a weak signal and a strong one comes on frequency, this is a consequence of the slice receiving more signal.  The NB threshold takes signal (noise and demodulated signals) level into account when you set it.  If that state changes significantly, then the effectiveness of the NB at the previous threshold level will not longer provide optimal noise blanking.  Optimally setting the AGC-T for maximum SNR will help in this regard, but it will not mitigate the effect.  Welcome to the wonderful (not) world of noise mitigation.
