Orange indicator LED
My fairly recent 6700 works well, but I recently noticed its indicator led glows dim orange when off but power is applied. I do not remember seeing this before. It does not have the GPS option, I am not using an XVTR, and cannot find much information on this in the documentation. Is the orange LED when off normal?
  • ctate243
    ctate243 ✭✭
    edited April 2017
    sounds like the remote on is selected in the radio information section of radio setup in SSDR.
  • Richard Mercer
    edited June 2016
    I do believe that was it-thanks. I received my Maestro earlier this week and I checked that function based on your tip. The remote start was enabled. Problem solved.
  • EA4GLI
    EA4GLI ✭✭✭
    edited November 2016
    Another LED state to keep in mind is TXing with the XVTR port versus ANT1 or ANT2. When you TX through the PA unit to ANT1 or ANT2 the LED is bright RED. When you TX into the XVTR port bypassing the PA it is an orange-red LED.
  • George KF2T
    George KF2T ✭✭✭
    edited February 2019
    That's normal - the TCXO is on.
  • Richard Mercer
    edited June 2016
    I appreciate the replies but the first one, from N6WM, solved the issue. I never saw this orange (dim) indicator until I installed my Maestro last week. At some point I inadvertently enabled the 'remote on' feature in the Maestro menu. Disabling it removed the indication.The key was it only occurred when the 6700 was off, but power was applied. Remote on evidently puts the 6700 in standby mode when it is off.
    Note that this is not covered in the 6700 documentation, that I could find.
    Again, thank you for the help.
    Rich W9YAC
  • Jay Nation
    Jay Nation ✭✭
    edited May 2019
    Richard
    Found it.
    With the v.1.7.30 release
    FLEX-6000 HARDWARE REFERENCE MANUAL
    Sections 6.6.1 6.6.2, page 20 of 48
    Explains the meanings of the LED colors.
    and
    SMARTSDR SOFTWARE USER MANUAL
    Section 30.4, page 136 of 181.
    Explains the Remote On button on the Radio Setup / Radio Tab
    I believe you couldn't find it.
    The Manuals are live documents, things move around from release to release.
    Those LED color Indications are likely software defined, as they have changed at least once since I got my 6500.
    There are several listings of the color meanings, if you Search "LED Colors" with the Community Search function.
    https://community.flexradio.com/flexradio/topics/what_are_the_fex_6000_front_panel_led_indications
    I almost quoted sections and pages from the v.1.4 release until I remembered to look at the current release.
    73, Jay - NO5J image
