Transmit temporary in usb
I noticed some interesting behavior today from my flex 6500. After using CW for about 20 minutes I switched over to lower sideband only to find that the slice was stuck in upper side band. Switching modes only seem to increase the band with the slice. I was eventually able to get it back into lower side band by changing the slice frequency manually. Just wondering if anybody else is seen this behavior before.
  • Tony C kc2dis
    Tony C kc2dis Member
    edited May 2017
    OK I have since read that other people had similar problems and in the future I will try turning my slice on and off to see if that solves it.
