Can I use an Ethernet to Wifi adapter on the 6500 Ethernet port to make it wireless?
K7NXT
K7NXT Member
edited February 2019 in FLEX-6000 Signature Series
I just received my Maestro today and would like to use the Wifi feature. However, my 6500 is not close enough to my wifi router for a hard wire connection. Can I use an Ethernet to Wifi adapter on the 6500 Ethernet port?
  • Mike va3mw
    Mike va3mw Member ✭✭
    edited February 2018
    You should be able to as long as it passes Level 2 communications.  Some do and some don't.  I have one that I need to test, but that doesn't help you today.   I just never got around to it.
    Mike va3mw
  • George KF2T
    George KF2T Member ✭✭✭
    Yes. Works as well as your wi-fi signal allows. You might consider a wif-fi extender with a built-in switch to connect your shack PC and Flex, That way, you have a solid connection for comparison, and can go wherever your wi-fi allows with the Maestro, laptop, tablet, etc.
  • K7NXT
    K7NXT Member
    edited June 2016
    Thx, I never would have thought to try that.
  • Watts - K4QJZ
    Watts - K4QJZ Member ✭✭
    edited June 2016
    I have had mixed luck with extenders and the type of network traffic the flex needs to pass. I would strongly recommend trying to use G (5ghz) not B (2.4Ghz) for your wireless link between your radio and your wireless router (less interference and greater bandwidth). It can work very well unless there is a great distance between your router and the radio. B goes further at lower speeds. I recommend you look for what is known as a "wireless bridge". Best Buy and others sell them, often thought of as WiFi adapters for game machines by the sales folks. These are usally a small stand alone box where you plug a network cable into your Flex and the other end into it. They can work great with the flex. K4QJZ
