What are the step to use the Hand mike with RJ-45 connection on Maestro.Ca not working on my side ?
Simon Lambert
Nothing audio with my microphone on the RJ-45 connection on my my Maestro?
What mic you using and have you selected right Mic input in config?0
The mic plugged into Mic 1 is the hand mic on the RJ45 connector. Make sure you select Mic 1 on the Mic selection.
Don't forget, there is a manual for the Maestro
https://www.flexradio.com/downloads/maestro-user-guide-pdf/
Check page 51 part 13.2.
Mike va3mw0 -
Thanks!I will check...
I have a Yaesu hand mike With RJ-45 connection .Normaly the pine out of the Flex are the same like Yaesu?0
The Yaesu MH-59 DTMF MIC won't work but the MH-36 does work on my Maestro, HOWEVER the PTT ground / Shield is on the wrong pin, it is on the MIC-- PIN instead of PIN7 on the RJ-45 like the manual says but seems to work OK, there is not even a wire to the FLEX GND pin on the RJ-45 on the MH-36 to tie too.
Be sure to set MIC input to use MIC1.
good luck
Bret
WX7Y
Thank's a lot I think you have find the problem!!!
Simon-ve2sim0 -
I Have the DTMF MH-48A6J microphone. And the pine out look's same.I will buy a Flex microphone...0
- 417 Community Topics
- 716 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
