Integrated amplifier control
Mark Erbaugh
Mark Erbaugh Member ✭✭
edited August 2017 in New Ideas
Add a button to the main screen to control whether a selected TX output is engaged in transmit. Label it AMP. When AMP is ON, limit the power out control to per band limit. When AMP is ON, multiply the values do the Power out slider by a gain factor. For example, if the amp takes 30 watts to drive it to its max of 1kW, the power slider would be labeled from 0 to 1000w, but would only but out 0 to 30 watts. Remember the AMP on/off setting by band/mode and for the TUNE function.
4 votes
In Review · Last Updated
  • Bill  /  VA3QB
    Bill / VA3QB Member ✭✭
    edited August 2017
    Great Idea Mark.   It should have an option to override the profile settings and the buttons on/off position should be remembered on SmartSDr power up.
  • WA2SQQ
    WA2SQQ Member ✭✭
    edited January 2017
    I've effectively done this using the Genovation key pad. I can toggle the "TX" controls and simultaneously send the CAT commands to set power level. It would be nice to have that as part of the GUI. ME TOO!
