creation of a slice on a band previously without a slice
Walt - KZ1F
Walt - KZ1F Member ✭✭
edited February 2018 in SmartSDR API
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    edited December 2017
    The sign said "Be the first to post a reply!" so here it is ...    what?????
  • K1DBO
    K1DBO Member ✭✭✭
    Do this, don't do that, can't you read the sign?
  • Steve K9ZW
    Steve K9ZW Member ✭✭✭
    edited March 2017
    @Walt - Section 8 of the manual describes it better than I can.
    For "SmartSDR for Maestro":
    Pressing the A or B RX button will place a Slice Receiver resource inside the corresponding Panadapter.
    A Slice Receiver will be created in the center of the Panadapter if none exists.
    If a Slice Receiver is already present in the Panadapter, the new Slice Receiver will be created with the same basic characteristics (mode, DSP settings, etc.) as the active or closest Slice Receiver to the center of the Panadapter with a mode specific frequency offset.
    For "SmartSDR for Windows":
    To add a Slice Receiver, click the +RX button in the Panadapter menu on the left side of the Panadapter.
    This action will place an additional Slice Receiver resource inside the corresponding Panadapter.
    A Slice Receiver will be created in the center of the Panadapter if none exist.
    Hope that is what you were looking for help with?
    Steve K9ZW
  • W4KCN
    W4KCN Member
    edited October 2017
    Not exactly sure what you are trying to accomplish, but you can check the Radio's slice list and determine from there.
