Flex-6300, N1MM, FLDIGI and CW not a love match
ON5AM
With N1MM and FLDGI this is not a love match in my shack !
When I use N1MM with MMTY I have no problem to make RTTY but when I use FLDIGI to make CW in the contest, N1MM always crashes !
Can you show me your solution
TKS
TKS
Greetings. I assume you are using a 6000 series radio? I will check with the N1MM list and see if I can see any issues in this regard. I do ask however why send cw with FLDIGI? You can use a winkey emulator port in SSDR cat to key cw directly from N1MM, or you can use an external winkey or equivalent.
I totally respect different work flows and what works for your paticular environment, but the potential to key the radio by taking FLDigi out of the mix is easily done. Let me know and I will help you with a solution.0
- 402 Community Topics
- 693 The Flea Market
