ATU power loss
AH0U
AH0U Member
edited April 2020 in SmartSDR for Windows
My antennas have SWR's of less than 1.5:1 and when I click on ATU it tunes says "success" and the indicated SWR on the bar graph is a little better but the power output measured on my Alpha 4501 s always about 18-20 percent less than without the tuner... is this normal for a 6700???
Tnx
  • Chris DL5NAM
    Chris DL5NAM Member ✭✭✭
    edited April 2020
    Only to understand right: for what reason do you need a tuner in TRX and a tuner in Amp at same time?
  • Ross - K9COX
    Ross - K9COX Member ✭✭
    edited June 2017
    All tuners have some degree of power loss. 18-20% is something less than 1db (26%). You probably don't really need a tuner to drive the Alpha however if you do just increase the drive level slightly to compensate for the slight loss.
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited June 2016
    Remember that the forward power as read on a meter is the power generated by the transmitter plus the value of the reflected power. So the forward power will always read higher when there is an SWR.
    Jim, K6QE
  • Jay Nation
    Jay Nation Member ✭✭
    edited May 2019
    Keep in mind that the external meter and the radios internal metering are sampling at two different points along the feedline, so they aren't seeing the same power and SWR values.
    And both might be correctly displaying power and SWR accurately, and still display different results.
    73, Jay - NO5J
  • Jay Nation
    edited August 2016
    Paul
    I'd bet it will account for most of it. Today's personal project will be to Google research the topic, and then apply my limited math abilities in order to calculate (yep I'll be using a calculator (broke my pencil lead recently)) the wattage in watts, and also in dBm, a 1.5:1 SWR mismatch will result in.
    I'm not sure I can figure out the real effect of the tuner losses involved, but they probably will account for most of any remaining difference. But first let me tackle my morning gallon of coffee.
    I don't believe in magic, however,  I do believe in both reality, and math, and I believe the application of both, might solve this mystery. image
    73, Jay - NO5J
  • Jay Nation
    edited August 2016
    Ok maybe I can skip the full presentation for a bit. but I'll redirect my efforts toward finding/blaming the losses in my shack.
    I remembered another issue that hasn't been mentioned ...
    there are mismatch losses due to the SWR, and also cable losses thru the cable with that SWR in existence on the  cable. along with ATU losses inside the ATU all to be figured in.
    In my shack I've got @30 feet of mixed RG8/RG8X coax and a 1.14:1 mismatch looking at my dummy load. Oh yeah, and 10 "perfectly hand soldered" PL259s, coax switches, and a bypassed Amp, wattmeter, and Tuner between the radio and the dummy load.
    Using online cable loss calculators, I can blame a 6 watt loss on @30' of copper. I know that each termination will produce it's own reflection. The  switch in cable types from RG8X to RG8 will also produce one.
    After letting the 6500/ATU find a match.
    Using Flexmeter.exe to take the readings inside the rig.
    I  see 87.07 watts of forward power
    I see .87 watts of reflected power
    I see a 1.14:1 SWR mismatch
    With the ATU bypassed.
    I see 93.39 watts of forward power
    I see 2.94 watts of reflected power
    I see a 1.3:1 SWR mismatch
    So at first glance it looks like I get better power output with a mismatch.
    or maybe ... somethings been miscalculated in the software. But which piece of the software. Flexmeter or the radio firmware. or is it just measurement error.
    I'd expect to see higher forward power into a mismatch, it's the matched
    readings that make me go HUH?
    So somethings not quite right somewhere.
    Not all that important to me because, my amp requires me to turn down to @70 watts output from the 6500, otherwise I trigger it's protection circuits.
    I still think I'm overlooking something simple though!
    The mystery remain mysterious!image
    Definitely worth figuring out, and applying the effort that the calculations might require.
    73, Jay - NO5J
  • Jay Nation
    edited August 2016
    More Google research, reminds me that Power and SWR measurements are not accurate when there's an impedance mismatch between the source, load, and transmission line, So SWR measurements of anything other than 1.1:1 when feeding a 50 ohm load, from a 50 ohm source, thru a 50 ohm transmission line, mean that whatever forward and reflected power readings might need to be taken with a few grains of salt. and that with my  1.14:1 SWR mismatch that seemingly small mismatch, is causing the losses in Forward power and also the increase in reflected power. Ok, I kinda knew that too. The point I was, well, ignoring is that with a mismatch, your SWR meter is likely inaccurate, and also the point, that a dummy load spec of "lower than 1.5:1" might mean that it's impedance is anywhere between 50 and 75 ohms. And that it might be the complete cause of the inaccurate readings, the only thing it's really good at is converting power to heat, while adding uncalibrated losses.
    So! Last months project was to place an order for 50' of RG8X, and 20 new PL259 and UG176 connectors. Which arrived this week. I plan to re-patch and re-shuffle all the equipment on the desk to create a spot for a Maestro. Hopefully I'll do as good, or better job as I did last time. and maybe remove some losses, by removing some coax length.
    Once I'm done with this project, I plan on Swearin off, SWRs fer good!image.
    Maybe, not knowing, is the best approach.
    73, Jay - NO5J
  • Jay Nation
    edited August 2016
    Paul
    I'd still like to figure out which of my wattmeters is closest to the truth.
    I suppose it's probably going to be the PowerMaster II, I paid the most for that one. It comes pretty close to Flexmeter.exe, most of the time.
    Thanks for those links. The whole point of this exercise is better understanding. The truth is out there, might as well use that!
    73, Jay - NO5J
  • Jay Nation
    edited August 2016
    Paul
    I'm beginning to suspect that, the reality is that you can get a reasonable power measurement from any of my meters, if you allow for the stated accuracy tolerance, and perform the test at the same point in the circuit. then all I need to do is decide which measurement I like the most. image and then sell the rest of them.image
    73, Jay - NO5J
