Connecting 6500 to Maestro & Computer
Joe - N7IV
I just unpacked the Maestro and 6500, connected then with the CAT-5 and connected the MIC, phones, and key directly to my 6500. It all works great. The problem is that the only CAT-5 connection on the 6500 is no longer available for connecting to my computer for N1MM+ access and keying. Is there a way to connect the 6500 directly to both without adding a hub (use the USB ports???).
Not that I know of. Just add a n Ethernet switch. It's no big deal.0
Exactly, use a switch. You will want to have a DHCP server in the network reserving addresses for each unit, or manually assign IP addresses, though. Makes life easier.
Thanks guys. That's what I thought, although I held out hope that the USB ports on the rig might work too or that the wireless LAN-connected computer could talk to the 6500 through the wireless Lan-connected Maestro. I'll buy a switch and assign the 6500 an IP number.0
- 117 Aurora
- 323 Shack Infrastructure
- 228 Networking
