PowerSDR_v2.7.2 and bug 30 at 6 meters...
f4fpq
f4fpq Member
edited February 2018 in FLEX Series (Legacy) Radios
Hello
I bought a used flex-1500 and I have problems with PowerSDR_v2.7.2 ...
The startup software is ok (with update firmware), I start the Flex-1500 it's ok, the button 160/80/40 are ok, I can surf ..
But when I chose the 30 at 6 meters, the software bug and on the screen (waterfall) the screen
becomes white color with a red cross .. . and above I have this message:
"Consultez la fin de ce message pour plus de détails sur l'appel du débogage
juste-à-temps (JIT) à la place de cette boîte de dialogue.
************** Texte de l'exception **************
System.OverflowException: Erreur de dépassement.
   à System.Drawing.Graphics.CheckErrorStatus(Int32 status)
   à System.Drawing.Graphics.FillPolygon(Brush brush, Point[] points, FillMode fillMode)
   à System.Drawing.Graphics.FillPolygon(Brush brush, Point[] points)
   à PowerSDR.Display.DrawPanadapter(Graphics g, Int32 W, Int32 H, Int32 rx, Boolean bottom)
   à PowerSDR.Display.RenderGDIPlus(PaintEventArgs& e)
   à PowerSDR.Console.picDisplay_Paint(Object sender, PaintEventArgs e)
   à System.Windows.Forms.Control.OnPaint(PaintEventArgs e)
   à System.Windows.Forms.PictureBox.OnPaint(PaintEventArgs pe)
   à System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   à System.Windows.Forms.Control.WmPaint(Message& m)
   à System.Windows.Forms.Control.WndProc(Message& m)
   à System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   à System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Assemblys chargés **************
mscorlib
    Version de l'assembly : 2.0.0.0
    Version Win32 : 2.0.50727.5485 (Win7SP1GDR.050727-5400)
    CodeBase : file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
PowerSDR
    Version de l'assembly : 2.4.4.31283
    Version Win32 : 2.4.4.31283
    CodeBase : file:///C:/Program%20Files/FlexRadio%20Systems/PowerSDR%20v2.4.4/PowerSDR.exe
    Version Win32 : 2.0.50727.5491 (Win7SP1GDR.050727-5400)
    CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Version Win32 : 2.0.50727.5492 (Win7SP1GDR.050727-5400)
    CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Data
    Version Win32 : 2.0.50727.5483 (Win7SP1GDR.050727-5400)
    CodeBase : file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Xml
    CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
    CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Flex1500USB
    Version de l'assembly : 2.3.2.1
    Version Win32 : 2.3.2.1
    CodeBase : file:///C:/Program%20Files/FlexRadio%20Systems/PowerSDR%20v2.4.4/Flex1500USB.DLL
wdapi_dotnet1040
    Version de l'assembly : 10.4.0.0
    Version Win32 :
    CodeBase : file:///C:/Program%20Files/FlexRadio%20Systems/PowerSDR%20v2.4.4/wdapi_dotnet1040.DLL
msvcm90
    Version de l'assembly : 9.0.30729.6161
    Version Win32 : 9.00.30729.6161
    CodeBase : file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57/msvcm90.dll
Interop.TDxInput
    Version de l'assembly : 1.0.0.0
    Version Win32 : 1.0.0.0
    CodeBase : file:///C:/Program%20Files/FlexRadio%20Systems/PowerSDR%20v2.4.4/Interop.TDxInput.DLL
FlexCW
    Version de l'assembly : 1.0.2.0
    Version Win32 : 1.0.2.0
    CodeBase : file:///C:/Program%20Files/FlexRadio%20Systems/PowerSDR%20v2.4.4/FlexCW.DLL
mscorlib.resources
Accessibility
    CodeBase : file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
atu
    Version de l'assembly : 1.0.0.12
    Version Win32 : 1.0.0.12
    CodeBase : file:///C:/Program%20Files/FlexRadio%20Systems/PowerSDR%20v2.4.4/atu.DLL
FlexControl
    Version de l'assembly : 1.1.0.0
    Version Win32 : 1.1.0.0
    CodeBase : file:///C:/Program%20Files/FlexRadio%20Systems/PowerSDR%20v2.4.4/FlexControl.DLL
czbe44vk
ajaadvka
TNF
    Version de l'assembly : 1.0.0.2
    Version Win32 : 1.0.0.2
    CodeBase : file:///C:/Program%20Files/FlexRadio%20Systems/PowerSDR%20v2.4.4/TNF.DLL
System.Management
    CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
System.Core
    Version de l'assembly : 3.5.0.0
    Version Win32 : 3.5.30729.5420 built by: Win7SP1
    CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
System.Drawing.resources
    Version Win32 : 2.0.50727.5420 (Win7SP1.050727-5400)
    CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Drawing.resources/2.0.0.0_fr_b03f5f7f11d50a3a/System.Drawing.resources.dll
System.Windows.Forms.resources
    CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_fr_b77a5c561934e089/System.Windows.Forms.resources.dll
************** Débogage JIT **************
Pour activer le débogage juste-à-temps (JIT), le fichier de configuration pour cette
application ou cet ordinateur (machine.config) doit avoir la valeur
jitDebugging définie dans la section system.windows.forms.
L'application doit également être compilée avec le débogage
activé.
Par exemple :
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
Lorsque le débogage juste-à-temps est activé, les exceptions non gérées
seront envoyées au débogueur JIT inscrit sur l'ordinateur
plutôt que d'être gérées par cette boîte de dialogue."
I use a computer with win 7 32bits / i3-2120 at 3.3ghz / 4go ram
I test on portable HP in 64bits... same problem..
I uninstall the drivers, uninstall the software for install :
PowerSDR_v2.7.2
PowerSDR_v2.6.4
PowerSDR_v2.4.4
PowerSDR_v2.3.5
Results : same problem..
Have you a idea..? 73,
Thierry F4FPQ
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    what do you mean chose the 30 at 6 meters?
  • f4fpq
    f4fpq Member
    edited May 2016
    Hello Bill,
    On the software when you select buttons bands 160 ... 40 ... 30 ... 20 ... 15 ... 10 ... 6 ... meters.
    As soon as you select the bands 30 meters there this a bug ..
    Thierry
  • f4fpq
    f4fpq Member
    edited May 2016
    In addition info :
    When I change the frequency with just the VFO A , i can go up to 50MHz ..
    But when i selected  the amateur bands radio frequency  ( 30 to 6m ) the bug happens ...
    Thierry F4FPQ
  • Bill -VA3WTB
    Not sure what is causing that, I can say it is not a bug. that has never happened to me over 10 years with my Flex 3000. It sounds like it is not switching properly in the rig. When I switch bands on my 3000 I could hear clicks inside.
    edited March 2017
    Reset you radio back to factory defaults (a database reset) as I suspect you have bad data in it that is causing the issue.
  • f4fpq
    f4fpq Member
    edited May 2016
    Hello,
    I can listen the click when i change bands ( when there's bug )...
    Very thank's bill for your respond 73.
    Thierry
  • f4fpq
    f4fpq Member
    edited May 2016
    Hello Tim
    And thank's for your respond,, have you a process for back to factory default..?
    Best Regard,
    Thierry
  • f4fpq
    f4fpq Member
    edited May 2016
    I test the reset Tim in :
    Setup / Hardware Config /  Factory Defaults = same problem..
    Thierry
    edited March 2017
    I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution.  If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
  • f4fpq
    f4fpq Member
    edited May 2016
    Very thank's Tim
    Best regards 73
    Thierry
  • ka7gzr
    ka7gzr Member ✭✭
    edited March 2017
    Tim
    Is there anyway for us to view the library of Tickets?
    Jim
    edited December 2016
    No.  HelpDesk tickets may contain personal information
