Key not parsed messages
Asher - K0AU
Member ✭✭✭
I'm getting debugger console messages:
Slice::StatusUpdate: Invalid key/value pair ()
Slice::StatusUpdate: Key not parsed (post_demod_low=300)
Slice::StatusUpdate: Key not parsed (post_demod_high=3300)
running FlexLib 1.7.3 against software 1.6.21 in the radio. Is the 1.6.21 API still downloadable or does everything need to upgrade in lockstep? Or are the messages unrelated to revision levels out of step?
Also these messages coming after the display goes to sleep. Anyone else seen anything similar? (BTW it would be great if the error messages could be in syslog format with timestamps)
On startup the client correctly connects to:
Discovered 192.168.1.180 FLEX-6700: 3313-0588-6700-2693 (xcvr-1 0x055D13BE)
then several hours late while sleeping it does this:
Discovered 0.0.0.0 FLEX-6700: 3313-0588-6700-2693 (xcvr-1 0x47B2ECFA)
Exception thrown: 'System.Net.Sockets.SocketException' in System.dll
Radio::Connect() -- Error creating TCP client
The requested address is not valid in its context 0.0.0.0:4992
Meter Packet: Expected 6 got 15
I also see hundreds of these messages along the way:
The thread 0x2554 has exited with code 0 (0x0).
The thread 0x3220 has exited with code 0 (0x0).
Asher,
Thanks for the questions. First, the key/value is debug output about data the radio is sending that FlexLib is not currently using. It is there mostly as a nudge to our developers if something appears there that shouldn't.
I'm not sure how to explain the 0.0.0.0 radio discovery. The radio should typically have a good IP address before sending out any discovery packets, so that is curious. If it were me, I would probably try to get it into this mode and divide the problem using WireShark to inspect the packets coming from the radio to decide whether it is sending a blank IP address or whether something is happening after that to cause the IP address to become cleared on the Discovery client side.0
- 409 Community Topics
- 707 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 367 FLEX-8000 Signature Series
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
